My car passed safety and is finally on the road and in the process of being broken in. The car runs well, the engine runs smooth and the handling is good. When the engine is cold, there is no problem with the starter cranking the engine, and it start right away. After running for about ten minutes and shutting it down and trying to restart right away, the (new) starter has a little more difficulty turning the engine over but it can still manage. After running it for more than 1/2 hr, the starter doesn't have sufficient torque to crank the engine over fast enough to start; let it cool off for about ten minutes and it can with some difficulty, but the engine can be started again.
It appears that the engine (or starter) seizes due to the heat. There is no indication of problems when the engine is operating (ie. no overheating, oil pressure good), even for extended periods. The engine has all of 400miles on it at this point (after a complete rebuild); the oil has been changed once, and with the exception of some bits of gasket, it appeared fine.
Has anyone run into this kind of problem before and if so, what was done to solve it? Will it go away as the engine loosens up?
I've installed a 6-1 exhaust header on it; the tubes run quite close to the starter motor (no contact) - could heat from the exhaust be causing the starter motor to overheat and seize up?
Thoughts?
Thoughts?
