james singleton
I intalled a back-up carb (single barrel) this afternoon and the engine appears to be running fine, but while adjusting the fuel/air mixture screw, I turned it all the way in and it did "not" stall or kill the engine. What is the normal problem when this happens??? Is it the furel/air mixture screw that is normally worn; or what??? Thanks, Jim
