Tony63 said
In my humble opinion, all of the "back cutting" and all for tricking out performance is money thrown in the wind. Shaving a few microns off the valve underside is not going to make any performance that you can measure.
Tony you are not correct about backcutting valves.
If you don't backcut the intake valves you are leaving HP on the table.
Port flow valves are not backcut, the port flow means the valve stem under the valve head in smaller in diameter than the rest of the valve stem.
The proper way to backcut valves is after the seat is ground or cut & the 45 degrees face on the valve is dreassed, then lap in the valves using valve grinding compound or apply prussen blue to establish the valve to seat contact area on the valve.
Then place the valve in a valve grinder & set the degree setting to 30 degrees. Then proceed to cut the sharp point of the valve seat to the lower lap in line.
Thats how you backcut a valve.
If i had my lawn mower engine apart i would even backcut the valve or valves to produce more flow.
I would guess you could gain possibly 5 HP by just performing this backcutting operation. Outlaw
