ozconv
New engine build has hit a wall as I am having trouble degreeing my camshaft. I would appreciate any advice. First some background. The camshaft is supposed to be a H264/274 112 lobe center from CI although there was nothing on/in the box to indicate that it is. Does anyone know if there should be a particular part number on the cam to identify it? I have installed the cam staight up with an adjustable double roller timing set also from CI. I installed the crank sprocket on the 0 degree slot and positioned the cam sprocket dot to be as lined up as possible with the crank key. I followed both cam degreeing procedures. For the centerline method, I got between 108 and 109 degrees. For the duration at 0.05" lift I got the following:
Intake opens: 5 degrees BTDC (0.05")
Intake closes: 137 degree BTDC (223 ATDC, 43 ABDC) also at 0.05"
Max Lift: 0.469"
If I add 223 and 5 that gives me a duration of 228 degrees at 0.05" lift. I am using higher ratio roller tipped rockers (bought from private party on this forum no documentation) that I have read can increase duration by about 3 degrees and lift by about 0.030" although my max lift is only 0.019" more than the advertised lift of 0.450". If that is the case I am wondering if I have a 274/274 cam since the duration at 0.05" for that cam is 224 degrees (add 3 degrees for the roller rockers and I'm at 227) instead of 214. Also if I index the cam sprocket one tooth either way, I don't get any closer to a 112 lobe center (more like 127) so I am now thinking that the cam might be a H274/274 108 LC. I did lightly oil (oil not assembly lube) the cam lobe and solid lift from the cam degree kit but I wouldn't think that would add 10 degrees of duration. I am also using an adjustable pushrod and low tension checker valve spring from JEGS. I've spent all weekend and probably a dozen attempts but none of the numbers are making any sense unless I have the wrong cam. I haven't checked the exhaust yet because I'll need to pull the head and switch the lifter over since I the kit only had one. Any help/advice would be greatly appreciated.
Max Lift: 0.469"
