350kmileford
Need help on an 'early model' Autolite 1100 carb:
Even after reading and rereading the info on the SCV on our early sixes, I'm still confused.
Currently I have a '66 200 with an auto tranny. A while back, I upgraded from a Pertronix to a DSII distributor setup. When I did the conversion, I simply used the same vacuum line (goes from carb to dist.) I assumed this was correct but was/am not positive.
A person is selling a unused Autolite 1100 carb on Craigslist. He lists it as the early style carb "Keep in mind its for the 67 and below sixes with the load-o-matic dizzies with an auto trans."
If I purchase this carb, will it work on my application? Can I easily alter it to allow it to run on my setup?
"The pictures are comparing the pony one to a 68+ autolite 1100 I took a few months back."
http://i42.tinypic.com/kcgkgg.jpg
http://tinypic.com/yourhome.php
