OK guys, here's my setup. 63 drop top falcon, Rebuilt '68 200, D8 ported head, offy with 34ICT/ICH webers, 800 RPM idle, 3.03 3 spd, 9.2:1, 206@.050/108 rapid lift cam about 2 degrees advanced, DUI at 12 deg (was at 14 but hot starting was difficult on the starter) any farther back to stock and the idle quality really, really suffers and there aren't any vacuum leaks. Now for the "issues". I can't really get it to run very well when I put a load on the engine. It (finally) idles OK with a bit of a lope and has 17in vac. When I take it out on the road, it'll stumble on take off and need a bit of throttle to keep it from stalling. Then when I floor it, it'll again stumble and cough through the carb - not really back fire but more like a strong stumble. Here's how I set up the carbs: Installed each indivdually on the center, set the idle screw and then the idle mixture via the vacuum gauge as high as possible then a 1/4 turn open more. When installed individually I found 60 idle jets to give me the best adjustment (3/4 turn out) with 50s being too small (lots of turns out to make any noticeable change to vaccum) and 70s being too bit (I could close the idle jet completely and it would run rough regardless of screw position). I put my uni-syn gage on the carb to and got a reading and tried to make each the same when they were individually installed. I then installed all 3. Without touching anything, on start up it ran aound 2500RPM. Sooo, I closed each idle screw down the same number of turns until I was around 1300. Then I attempted to use the carb sync gauge to balance them. The only way to make the gauge go up or down was to turn the idle speed screw. Idle jet screws did nothing. The carbs were actually pretty close on the gauge. Next, I closed the outer idle speed screws to completely close the butterfly and had to go up on the center carb idle speed to keep it running. It then ran poorly and rough with vacuum down to 13-14 inches. Turning the idle jet screws closed caused it to smooth and increase vacuum. So I dropped jet sizes to 50 and found 3/4 turn out on all 3 to give me the highest vacuum around 16-17 inches. Once the idle speed screws were closed on the outers, the gauge dropped all the way down and turing the idle jet screws did nothing to the gauge - so I guess the carbs are not balanced. My collection of idle jets are 3 each of: 45, 50, 52(qyt2), 60, 70. I have 2 HW5200's that have 170/190 main/air jets that'll fit the 34s. I know the main jets on the 34s are currently 155 on the outer and 170 on the center. The center air jet is 190 and I don't recall what the outers are. Can anyone give me really basic step by step instructions on balancing - apparently I'm not the sharpest tool in the shed. :roll: Also any thoughts on the stumble? I'm basically finished on a 5 year build and have to get it running so that I can finally register it.
TIA
TIA
