mustangman33
I was told it was not necessary to put a gasket between the block and the oil pump. The oil pump I got only came with a gasket for the pick up screen. I was looking at the shop manual and it said that you are supposed to put a gasket between the oil pump and the block. So am I supposed to put a gasket between the oil pump and the block. Its a 78 200 block. Another question is the shop manual also says to prime the pump by putting oil in it, is that necessary? Thanks.
