electrorc
06/09/2011 Edit: This is from last year, so check towards the end of the thread for more recent info.
The 200 in my Mustang let go back in August. It had really low compression and a completely dead cylinder—compression was around 90 for most cylinders, 60 for 1 or 2, and 0 for another. I eventually pulled the valve cover and found a pushrod that had bent and was broken. I tried just replacing it with a new one, but it ended up just dropping down too much to reconnect to the rocker arm.
I haven’t been able to pull the head off yet since there’s no room in the garage, but I’m assuming it’s going to need a total rebuild. Instead of rebuilding it, I wanted to just get a reman engine to save some money, but I can’t find anywhere that actually has decent comments about them. I had a couple of local shops recommended to me, but I’m not sure what to do for parts. The Classic Inlines rebuild kit seems to end up costing quite a bit more than the one from Clifford, and then of course there’s the ones from Sealed Power and what not, but they all include different things. The head and exhaust manifold on the engine right now have a date code from ’63, so I’ll probably end up purchasing a rebuilt '70s head or maybe trying to find one from the junkyard and getting it rebuilt.
The car will be a daily driver, so it needs to be reliable. I’d also like a little bit of extra power than stock for if I end up going to the strip or autocross or anything. I’m also on a budget, unfortunately.
And one other thing… I keep seeing something about an adapter that lets you use the 3.03 3 speed with the 2.77 bellhousing. Since I’m not having any luck finding a later six around me, is this a good idea? Where can I find it?
Thanks!
Thanks!
