got it for 60 bux, came with new looking springs, a valve cover and rocker assembly, it came out of a late 60's falcon how much should i mill off to get 11/1 comp with dished pistons
64 200 ranchero":2di5y8v4 said:how mutch to get it to the stock comp? how many cc's were stock on these heads
not if you have adjustable rockers.64 200 ranchero":1k6lh2nm said:turns outthe head was cracked and valve guides were worn, he said that if i mill down the head that i would have to get shorter pushrods is that true
64 200 ranchero":2g0ut4jf said:the crack is next to the valve guide, he also said the valve guides are shot
