Hi All,
Here’s a problem that you may be able to help with. Car is Mikey’s 72 Comet 250 six. Over the past couple of weeks the drivability has gone downhill, to the point where it just is not a viable vehicle. It misses something terrible at idle, very erratic and may or may not stall. It acts somewhat like a massive intermittent vacuum leak. The carb idle mixture adjustment can be screwed in all the way and it doesn’t seem to make any difference.
First I replaced the carb with another recently rebuilt Carter RBS. Same thing. I checked all the hoses and made sure there were no leaky vacuum diaphragms, transmission modulator, heater control valve, distributor, etc. New hose to the PCV valve, which was also replaced. I made up new gaskets for the carb to adapter and adapter to manifold.
I checked the compression, all 140-150 except number six which was 110. It read the same last year when it was running better.
Replaced the spark plugs. The old ones looked good on the insulator, nice light tan, but black around the outside. Number six looked just like the others. The timing was checked, it hadn’t moved, about 15 degrees BTDC.
The car had a Duraspark II conversion with an Accel coil. I replaced the whole ignition system with the stock points distributor and black Ford coil. Jumpered directly from the battery to the coil to eliminate wiring problems. No difference. So it isn’t ignition related.
When I short out each spark plug individually the engine speed goes down or rather the vacuum decreases. It’s hard to tell because it idling so poorly. Number six is firing just like the others, speed drops when it is shorted out.
The engine has NO internal noises; lifters are quiet also. The oil has been changed recently. It doesn’t use any water so don’t think the head gasket is bad. Only 67 thousand miles, far from worn out.
Anybody have any ideas? I’m open to suggestions, except to replace the motor with a V8.
John and Mikey, at a loss in Kalifornia
