Shortblock is done.
Starting on final parts of head Friday, will be ordering valves, valve springs, retainers, and keepers.
What kind of valve spring rates should I be looking at for a turbocharged 200 L6 that is rev limited to 6000rpm. Looking at 20lbs boost maximum.
Was eyeballin these: http://classicinlines.com/proddetail.as ... 302-SPG-HP
It is my understanding high boost turbo engines need higher spring rates closed to keep high boost pressure from blowing valve open when closed.
At what point should I move to dual spring setup?
Thanks,
Mark.
Thanks,
Mark.
