69.5Mav":1vyd5a8m said:
Wellllll, ..... We may have figured it out... I had some friends go out with me last Saturday... I installed a 1bbl downdraft carb off of a car and plumbed a fuel pressure gauge into the line. One of the friends ran the throttle while I drove. It ran great ... for about 25 or 30 seconds, then fell flat on its face, like it had been doing. The fuel pressure had dropped from 8lbs, down to zero right before stumbling.
A quick update on the fuel sysytem... tank had been opened-cleaned and fresh liner installed, freshly rebuilt mechanical pump on engine, new fuel filter/water seperator installed and all new fuel lines. I had been running a Carter electric fuel pump on the boat for the last 5 years. The guy that rebuilt the mechanical pump said it was ok to leave the electric one in the line, before the mechanical one, as a back up.
We decided to run a temporary hose around the electric pump to bypass it.... We were on a small interstate pond, so it was hard to give it a good test. We did make 4 or 5 passes and overall it ran pretty good. I then installed the sidedraft carb with my homemade adapter back on the motor. There is a bit of a high speed bog, that hopefully some carb tweeking will take care of.
When I got back to the shop, I removed the electric pump and it wont do anything when bench tested. The only thing we can figure out is the electric pump must have some kind of a restriction in it when the fuel flow rate is at a certain level?
I am hoping to get her out another time or two to check it out some more, but the season is getting real short up here.
Keeping my fingers crossed!
