Dumb question on head replacement
lorwood
Post #1 by lorwood » Mon Aug 30, 2010 9:10 am
Sorry for the stupid question did a search been reading as much as possible but I guess I really need this dumbed down to fit inside my brain.
First the stats
68 200 block
Installing a street build D7 head from CI 2v conversion
Will compliment with a 32/36 carb and DUI ignition.
OK First question.
If I am understanding this correctly (doubtful) with non adjustable rockers and hydraulic lifters there really is no valve adjustment is this correct? If so before installing rockers should the number one cylinder be set to TDC or does this not matter?
Second
Is installing the DUI after the head install has been completed the proper sequence?
Again my apologies to the true gear heads here and as always thanks for sharing your expertise.
Ed
80broncoman
Re: Dumb question on head replacement
Post #2 by 80broncoman » Mon Aug 30, 2010 9:54 am
lorwood wrote:.....OK First question.
Won't matter one bit.
lorwood wrote:Second
also won't matter which you do first.
OAPSE Union Member
Real men don't wear Bowties
lorwood
Post #3 by lorwood » Mon Aug 30, 2010 12:03 pm
Thanks! I have a fatal flaw in that once I understand something I find myself saying "It can't be that easy I must be misunderstanding the subject"
early ford fan
Post #4 by early ford fan » Mon Aug 30, 2010 4:59 pm
i assume that since it came from ci that it has been cut for the proper compression ratio?
lorwood
Post #5 by lorwood » Tue Aug 31, 2010 7:15 am
early ford fan wrote:i assume that since it came from ci that it has been cut for the proper compression ratio?
Correct. Since its just a street build trying to stay close to the stock CR. Thanks
Lazy JW
FSP Moderator
Post #6 by Lazy JW » Tue Aug 31, 2010 9:59 am
lorwood wrote:......
Second
Is installing the DUI after the head install has been completed the proper sequence?.......
It really doesn't matter all that much but if I installed the DUI first there is no doubt that I would somehow manage to drop the head on it..... :twisted: :oops: :bang:
"The White OX" 1974 F-350 300-6, Stock single exhaust, Carter YF, T-18A, Dana70 w/4.11, Flatbed dually w/dump bed. "Where no oxen are, the crib is clean, but much increase is by the strength of the ox" (Proverbs 14:4)
JackFish
Post #7 by JackFish » Tue Aug 31, 2010 11:52 am
I would put the engine at TDC before putting the head on. There isn't a better time to verify it exactly with a dial guage.
Yup, I bought another one.
1996 Chevy Caprice 9C1 (3)
1999 Dodge Ram 2500
Lazy JW
FSP Moderator
Post #8 by Lazy JW » Tue Aug 31, 2010 2:41 pm
:nod: :thumbup:
JackFish wrote:I would put the engine at TDC before putting the head on. There isn't a better time to verify it exactly with a dial guage.
JackFish
Post #9 by JackFish » Tue Aug 31, 2010 2:58 pm
Lazy JW wrote::nod: :thumbup:
Better that than another "I just put my head on how do get I tdc?" post. :rolflmao:
1999 Dodge Ram 2500
lorwood
Post #10 by lorwood » Tue Aug 31, 2010 5:21 pm
Any tips on setting the dial gauge up? Does it bolt right on to the block or will I have to rig something up to hold it stead for an accurate reading? Thanks
JackFish
Post #11 by JackFish » Tue Aug 31, 2010 7:24 pm
It should have a magnetic base.
1999 Dodge Ram 2500
lorwood
Post #12 by lorwood » Tue Aug 31, 2010 7:34 pm
JackFish wrote:It should have a magnetic base.
Great! Thanks
early ford fan
Post #13 by early ford fan » Tue Aug 31, 2010 9:28 pm
you can also bolt a piece of metal across the cylinder and use a feeler guage to find tdc.you will have to decide which guage.
Lazy JW
FSP Moderator
Post #14 by Lazy JW » Tue Aug 31, 2010 10:02 pm
early ford fan wrote:you can also bolt a piece of metal across the cylinder and use a feeler guage to find tdc.you will have to decide which guage.
Yup, that works too; this method can also be used as a piston stop to find TDC. I prefer the dial indicator but not everyone has them.
Joe
Users browsing this forum: lavron and 30 guests
