SoCar72
A couple of weeks ago the Falcon burped some coolant. Checked the radiator, found it low, added coolant, temp tested it, all was fine.
A few days ago, temps spiked hotter than common, then came down to typical. Found my coolant low again, added, all was fine again. Suspect a sticking thermostat. :!:
Just yesterday, did it again. Time to replace the thermostat. Temp got high, but never not outside of "normal".
Today, similar spike, similar return to typical. Then temps started running all over between typical and hot, still never above "normal". New development : a lot of steam coming from the exhaust, like on a cold morning, but the weather is dry and mid-60's. Checked the coolant, 1/2 gallon low.
I suspect a blown head gasket (shim) letting coolant into the combustion chamber. I haven't checked which cylinder yet. Oil and coolant are not mixing. Exhaust is not smoky, but steamy, excessively steamy. All runs well otherwise. What's the likelihood of this? Perhaps the head cracked? :arg:
I think I'm going to source up a head gasket and try swapping it first before I commit to replacing the head or engine (I want to swap for a 7-main anyway).
Thoughts or experiences? Advice?
