Gene 64 2dr
I am having a problem with one of my lifters. At first I started to have a problem with noisy lifters. I thought I my have damaged some because I drive it pretty hard with a few runs down the drag strip. I would adjust them but the noise would return in a very short time.
I replaced the complete set of lifters but the problem still remained.
I finally found out where the noise was coming from.
When adjusting the lifters with the engine running all the lifters adjusted correctly but one. The lifter for the intake on the #6 cylinder when backed out until it clatters then adjusted to remove the noise would after about thirty seconds start clattering. Preloading another ½ turn would eliminate the noise but after another thirty seconds or so it would return. This continues until the lifter is completely collapsed. I thought I may have a bad lifter so I replaced it but have the same problem. There is plenty of oil pressure.
Any Ideas as to why I’m having this problem.
Gene
Gene
