Johnsondawg
I'm working on a converting my 200 with a 3 speed to an Automatic (C4). I currently am still running the three speed but I want to switch over to the Carb for the Automatic ( Two Dashpots ) so that I can get it dialed in before I swap in the C4. I also want to use the Auto carb because my current carb has the spark control valve and I am no longer running the Load-o-matic dizzy. Its my understanding that when you get rid of the load-o-matic you should also get rid of the carb with a spark control valve. So is there any problem with running this before swapping in the C4?
