ford 200 ci log head freeze plug
dawnovsky
Hi,
need to have the freeze plugs from the cyl head change on my mustang 200s.
What is the correct size for those plug (those 4 located between cylinders behind exhaust manifold)
i can found almost every std size in inches at my local store.
it seem s to be 1 or 1 1/16, but i would appreciate confirmation before removing the old on and find out i don't have the correct one on a sunday morning ...
regards
I have 4 and they are 1”. They are easy to remove. Use a flat-head screwdriver. Place the tip at the bottom inside rim and drive it through with a hammer. It will spin at the center contact points. Us channel locks and pull it out.
Clean the holes with 400 or 320 grit and lacquer thinner or disk brake cleaner.
I mixed a small amount of JB Weld for each plug. Thin thin coat on the head walls and a small bead around the plug. Use a socket that will fit the ID of plug and drive it home..
