like the topic implies... I want more
recap of current setup
78block 200ci
ARP rod bolts
double roller timing chain
264/274 110 .450 cam
1.5 stock rocker arms
9.3 CR
78 hex log heavily ported and valve guides
1bbl 1100v
DUI
15000 miles since rebuild
goal
MORE POWER (200+ rwHP)
keep the six!
I have thought of going bent, but I do want the six...
I have thought of getting the alum head 4bbl intake, but what if that doesn't reach my goal?
according to classic inlines dyno 2
http://classicinlines.com/Dyno2.asp
I have the same bottom end, and would need the head, intake, 4bbl, roller rockers....
I have even thought of adding juice :nox:
I have thought of going 2bbl direct mount, but that will problably put me in the 130hp range, so that won't work out too well
the 3x1bbl route could work but one already dyno'd it out to 166hp.... and probably the worst MPG
I would still like to maintain minimum 20mpg city, I'll go anything over that....
I'm asking you guy's is there anything that I have not thought of, that I can do my self, of course I would like to keep it naturally aspriated 200hp as here in AZ it gets hot, and turbo/super would be that much harder to cool...
I know I can reach 200hp, I know of one route so far, but it's costly, and worth it, but is there something I have overlooked?
78block 200ci
ARP rod bolts
9.3 CR
1bbl 1100v
DUI
goal
keep the six!
