Alright, a small update. Sooooo... The new spring I bought went in the carb and it did allow the pump to work like it should. So now the car idles nearly whisper quiet (at 600rpm), accelerates smoothly, but that is about it. When the car gets up to speed and I guess when the carb switches to the throttle circuit, the cars starts running rough and at any RPM over 2500 is very rough. Now I have a small question regarding the structure of the RBS carb. The only thing I had trouble replacing in the carb was the step-up rod and diaphragm. The new one developed a tiny hole as I was trying to install it, so I had to put the old one back on. What does this part do and would an old/not very flexible one, cause the car to run roughly at part throttle?
Thank you all! I know with all the knowledge on this board, I will be able to get my Mustang back on the road again.
