I'm about to the point of swapping out my direct fit alum 2row radiator for a 65 mustang (17Wx16.5H)with a 2400cfm fan to a 69 mustang 250 alum radiator (24Wx16.5T) with a dual electric fan setup that has 4000+cfm
my end goal is to run a 195* t-stat all year long and never have it run above 205* no matter the outside temp (I want my mechanical guage to never pass the 195* mark again)
I have racked my head around this topic so many times I'm afraid I'll start quoting it...
General Discusion on Heat
I'm afraid I just don't have sufficient enough cooling surface area
I have flushed the whole system countless times, (forwards and backwards) and it's "clean" coming out.
I have been conviced by my cousin to flush one last time try water wetter with 25% coolant, and the rest water, and if it doesn't fix it I'm pulling the plug...
the radiator does AMAZING when it's cool outside, when it's 80* or cooler, but go to 95* outside and it's warming up and don't forget tripple digits, I'm not aloud to run my AC cause I'm running 230*!!! on a 105* day (using a 195 t-stat!)
I don't understand WHY this same size radiator can cool a 400hp v8 but not a measily 115hp i6!!! it's ridiculous!!!
so, anyone out there wanna suggest somthing? I'm really desparate as I'm honestly planning a major remodeling of my radiator support to nip this thing in the butt once and for all
just for kicks and giggles, I'll run my 3 core copper radiator till my new radiator is in... it might cool better than this POS...
