<<< New Site Update >>>
Another Cam question - calculating total lift
sp_alloy_head
Post #1 by sp_alloy_head » Tue Jan 03, 2012 8:59 pm
I'm trying to figure out what the exact lift is for
my solid lifter cam.
1.) .480 total lift / 1.5 rocker ratio = 0.320 Lobe lift
2.) 0.320 lobe lift - .014 valve lash = .306 inch
3.) .306 in. lift * 1.5 rocker ratio = .459 net total lift
So the total net lift is .459", right?
Cam Specifications:
Intake Duration (gross): 274
Exhaust Duration (gross): 274
Intake Duration (.050”): 228
Exhaust Duration (.050”): 228
Intake Valve Lift*:===== .480"
Exhaust Valve Lift*:==== .480"
Lobe Separation:======= 110
Intake Valve Lash:===== .014"
Exhaust Valve Lash:==== .014"
Re: Another Cam question - calculating total lift
Post #2 by bubba22349 » Tue Jan 03, 2012 9:11 pm
No I would think it still would be .480 total lift, the .014 valve lash is for clearance only it shouldn't reduce the lift. Though you would need to set it up on some V blocks and measure it with a dial indicator to know it’s exact lobe lift. The other thing that can vary are the rocker arm ratio's again you would need to plot total lift with a dial indicator at valve with the cam and rockers assembled in your engine.
wsa111
FSP Moderator
Post #3 by wsa111 » Tue Jan 03, 2012 10:17 pm
.480"-.014" = .466 net lift.
Your duration @ .050" is closer to 218 degrees cause you have to figure the valve lash into the real duration. Bill
sp_alloy_head
Post #4 by sp_alloy_head » Wed Jan 04, 2012 2:38 am
Okay, thank you for this information. I'm looking for a cam to remedy my too-high-CR and I'm hoping this will help bleed off some pressure.
Does10s
FSP Moderator
Post #5 by Does10s » Wed Jan 04, 2012 8:50 am
Valve lash has nothing to do with valve lift. When the cam lobe it at the top of it's rotation, there isn't any lash! Everything associated with that valve is tight. So there's absolutely no way that valve lash can effect total lift.
Lash does change the duration for sure! The more lash, the less duration. The cam has to rotate just that mush more to take up the slack. This goes for both the upslope and downslope of the cam lobe.
Later,
Will
'86 Mustang, Turbocharged, Best ET: 10.70@132.
'69 Mustang Sportsroof, 351w, auto
'63 Falcon, Turbocharged 250, C4, 9", Best ET: 10.64@127mph 11/21/14
wsa111
FSP Moderator
Post #6 by wsa111 » Wed Jan 04, 2012 11:11 am
The gross lift is the measurment from the bottom of the base circle to the top of the lobe, minus the diameter of the base circle. Then multiply that figure by the rocker ratio & thats your gross lift.
The net lift you subtract the lash from the gross lift. Bill
sp_alloy_head
Post #7 by sp_alloy_head » Wed Jan 04, 2012 11:48 am
Does10s wrote: The cam has to rotate just that mush more to take up the slack. This goes for both the upslope and downslope of the cam lobe.
I can picture this in my head, it makes total sense.
@Bill(WSA111), I'll add that to my notes, I was overthinking the whole lash / lift aspect.
Thank you to Bubba, Does10s and WSA111.
Users browsing this forum: No registered users and 30 guests
