Route--66--
Related to another topic I posted about piston slap.. I was looking at how the bores are lubricated .. which is apparently by the crank 'splashing' the oil up from the sump to inside the bores.
On these engines is the wrist pin / little end, lubricated by the same method?.. or by some kind of oilway up the middle of the con rod?
I read this morning that if you use a thinner oil (I currently use 20/50) it would lubricate the wrist and cylinders better when cold and reduce my cold piston slap (the slap is certainly not massive, but is noticeable).
Is this true .. as, if the oil is being splashed up there anyway surely it wouldn't make a difference if the oil was thick or thin as far as the cylinder walls are concerned, (although might make a difference to the wrist pin)???
Cheers
Cheers
