improbcat
I'm trying to pull the cracked exhaust off my "new" '66 200 motor and it doesn't want to budge. All the bolt heads are rusted enough that a wrench/socket doesn't even fit properly anymore and I tried using these bolt extractors but the correct size spins without grabbing and the next size down doesn't fit over the bolt head.
Any suggestions? Unfortunately I was an idiot and put the engine in the Falcon, so I'm trying to extract it in the engine compartment. And I can't even ignore the leaking manifold until nicer weather because the studs for the exhaust pipe mount are chewed up as well.
I can take pics if it'll help.
