67-Conv-200
Active member
Hi,
My engine has developed an odd oil pressure issue since changing the rear main seal and oil pan gasket.
- When at a stop light after heavy load (freeway at 65-70 for 15min), my oil pressure guage drops very low (almost like turning the car off). it goes back up once I start driving and will happen for a few additional stops before returning to normal.
- This only happens when it is warm outside 80F+
- Shifting into neutral at the stop keeps the oil pressure at normal levels.
- If I stay on the side roads the pressure is fine.
- I have only verified this with the guage on the dash, I don't have another gauge yet.
- Car is running on 10w-40 conventional oil.
- Oil is filed to the full line on the dipstick.
I am not sure where to look for this issue, but I am guessing the oil pump. Does anyone have any other ideas? Should I use 10w-30? I am planning on going back in there to fix the rear main seal next weekend so I would appreciate any suggestions that I should look out for.
Thanks.
Thanks.
