anotherhassel
So not sure if you guys saw my thread about my mis but it turned out to be a vacuum leak. So I ordered these bearings that were supposed to fix the leaking throttle shafts. But they didnt mention that the bearings dont fit the dfav weber only the dgv weber :x. So i am now stuck with getting a new carb. So I guess my question is do I go back with the 32/36 or should I look into the 38? I have read Mikes tec on the both of them and it says the 32 may be better. However I also have been to Falcon fanatics web page and he has the 38 and had it on a pretty much stock engine before he did his head work yada yada yada. So I am pretty much stock with headers a weber (duh) and a petronix . I am looking to eventually get a duraspark but i need my car to run right now! It is idling so bad and she feels down on power all the way around. So any and all help is much appreciated!
