We plan to offer two kits.....one with rockers only, the other with rockers and a new shaft, or fully assembled and ready to bolt on. You can also mix the ratio's when ordering. For example, you could use 1.5 on the intake and 1.6 on the exhaust, or vice versa. The best part about making our own line of rockers, is that we can make any ratio we want, from 1.5 to 1.75 (custom ratio available on request). We also started from scratch, rather then modifing a shelf rocker, so we could make them the same width as the stock rockers. This means they slip right on, without any special parts, a longer shaft, or any modifications.
As for cost, I'm still working on it... but they will definitely be cheaper than the ones we were offering. I'm just guessing but I think the rocker only kits, regardless of ratio, will run around $375 (plus $30 for a new shaft).
Other good news, I found a manufacturer that will make custom Hypereutectic Piston for us. The best part, they'll only cost a little more (10-20%) than a stock cast piston, and I can have high performance coatings (top and skirts) applied at the factory. Bad news, I have to order a minimum of 1000 pistons, so it's a sizable outlay of cash. Time to start saving....
