canvaspaul
Hello everyone,
some pictures from the mustang I bought yesterday for my son, its a 1979 fastback and of course a 6 inliner.
Sorry for the pore quality of the pictures better ones will follow.
Today I preformed some checks (yes, stupid that I did not do this before I bought the car normally I do but it was raining cats and dogs) like oil and cooling water.
On the dipstick of the engine oil I found some Mayonnaise, most of you now already know what I mean.
Also under the breather and of course the valve cover.
After removing the cover its confining to one hole, as you can see.
I turned the 2 bolts on both side a little bit faster, but i presume this will not do the trick.
Suggestions??
Try every bolt a little faster?
I have only ones try to replace a head-gasket (4 cylinder and now the are 6) and that was no success.
Car is running on LPG (gas)
Thanks.
Gr Paul
Suggestions??
Thanks.
Gr Paul
