JAGGUY
Active member
So I decided to detail the 200 engine in my '66 Mustang.
Stripped all the bits and parts off the block. Discovered the timing tab is bolted to the timing cover so I remove that.
Under the tab is the timing marks cast into the timing cover. From what I can tell the numbers and the position of the marks are the same.....
Any reason for this?
