The advice of others will help. Been there, done that, and have the results to back it up.
Most guys here use lots of intial timing on the crank. I don't like that method, but I do run a heap of advance because I use the Ak Miller method of advancing the heck out of the inital crank timing, then back off 0.5" Hg of idle vac. I got 16 deg that way.
These links and my dial back tming light and engine analyser are the key tools.
http://1bad6t.com/Maverick/diagrams/DSSPECS.htmL
http://www.carbdford.com/viewtopic.php?t=5392
http://www.carbdford.com/viewtopic.php? ... highlight=
Find total vac advance requirement
Cam duration-----Idle speed expected------------------Advance
----270------------------600-800----------------------------10-12
----280------------------900-1000---------------------------12-14
----290------------------1000-1100-------------------------14-16
----300------------------1100-1200-------------------------16-18
----310+----------------1100-1400-------------------------18-20
For our good 2-bbl Falcons down here, we'd limit inital advance, with 264, I'd use 9 degrees static, and 36 degrees total by 2800 rpm with 9:1 c/r,
8L slot = 16 degrees centrifugal advance = .358"
9L slot = 18 degrees centrifugal advance = .384"
10L slot = 20 degrees centrifugal advance = .410"
11L slot = 22 degrees centrifugal advance = .436"
12L slot = 24 degrees centrifugal advance = .462"
13L slot = 26 degrees centrifugal advance = .488"
14L slot = 28 degrees centrifugal advance = .514"
For mine, I need and use ported vac , but emission set ups are something I use rather than dispense of, and at the moment, I use a locked Duraspark with Boss 302 style 16 degrees static, and 25 degress total at 2500 because I've planed my head 120 thou to get a 12.7:1 c/r. I can't afford to blow up my 87 octane engine, so I use sharp intial and very mild total advance, and positive stop and reprofiled arms, via a welded up 0.267" second slot on my 510L sleeve assembly.
The Ford Duraspark isn't as Manifold Absolute Pressure sensitive like a mapped EDIS, but its curve plotted is dynamic. The Duraspark 2 is a smart system, and if you map it like the Meqasquirt system, you'll see how it works.
