chessterd5
I'm sorry, I obviously need to clarify.I meant a screwdriver that's three or four feet long w/ a plastic handle.After 14 years of being a professional mechanic, (10 at a dealership, 4 on military vehicles) I can assure you this is standard practise for finding noises & vibrations. Yes, a stethescope is the proper tool but, I personally prefer to use a very long screwdriver for multiple reasons: 1) I believe it's safer because most stethescopes have a metal end that is only a foot to maybe a foot & ahalf long attached to a rubber hose. Wich means you have to extend it w/ your arm to reach into the engine compartment.W/ along screwdriver you can hold the handle right below your ear 2) With a stethescope you have two ear pieces in your ears wich may pull your head down or get caught on eye glasses, safety goggles,etc. A screwdriver you can let go or be pulled away from you. It's not attached. 3) THe lenght of it allows you to have your head &ears out side the engine bay or out from under the chassis if on a lift. for better diag. 4) If you've ever bought a high dollar stethescope off the "tool" truck for x amount of dollars per week to burn a hole in the tubing or melting an important plastic component on a hot exhaust manifold... it can be quite frustrating. I apologize, & will atempt to be more specific in the future.
