65-coupe
I am in the process with Mustang Monthly doing a tech article on the install of my new head. This started a few months ago when we dyno tested my car the way it is. Only 80HP to the rear wheels. We are going to dyno after the install with the C4 and then the T5. Last Weds we pulled the engine and stripped the engine compartment for paint. Still waiting on my head from CI it is having port work done. I will be installing a 264/264 110 cam, 1.6 roller tipped rockers and alot of other new parts from Summit, Spectre and Lokar. Summit had a alum water pump that I got from them. I will be using a 1.14 2100 carb that I have. I plan to upgrade to a 4100 in the future. When we pulled the oil pan the bottom end was very clean. It has also been balanced when the last person rebuilt it in the early 90's. The article is planned for the October issue as long as all goes well. You can go to Mustang Monthly's facebook page and see the pic of us pulling the engine.
Brian
Brian
