Plan on making intake and exhaust,.. why would I need a cam that's different from what comes in the block?rocklord":18y03req said:Realize that you will also need the crossflow cam, intake, and exhaust/header.
US parts will not work with this head.
mike1157":dr5mq9rd said:Can I get one? I've tried a couple of Aussie eBay sale sites,.. they either don't reply, or state that it's too much trouble. Can someone point me in the right direction.
Aussie Crossflow cam - US cams will not work since the port arrangement is different. The stock EFI cam is a good choice for a mild engine. Crow Cams makes a variety of hotter cams, as do other Aussie cam vendors.
chad":2lmktyjo said:I didn't see the cam change requirement in all the swap-over stuff I've read these 10 yrs either. As a non mechanic of engineer I must have missed it too.
Thank you.
I had hoped to switch back and forth, but reality has sunk in (finally).
Even the earlier heads (iron) would require the cam change in an amerikan 250?
pm'd yousuper4ord":3nauvfz3 said:I have an aluminum crossflow head that I'd be interested in selling or trading. I can send you some pics after work, if you're interested. I have one each: valve cover gasket, head gasket, intake manifold gasket to go with, plus some other stuff too. I have too many projects, and don't think I'll ever get to this, or it will be years down the road.
Darrell
