67drewstang
So, as I've posted in my build thread, I have purchased a 1980 head that has been milled, ported and a new valvetrain installed to put on my 1967 small log engine.
viewtopic.php?f=1&t=71441
I am going from an Autolite 1100 to a 1200 with a manual choke, and am wondering what to do with all the additional holes in the new manifold. My old manifold has one small hole on the side next to the carb, with a pipe leading up into the carb. The new manifold has a hole atop the manifold and a milled bit next to the carb mounting pad on the side which has two threaded holes and an unthreaded hole.
What I'd like to know is a) is it necessary to mount something there, and b) if not, what's the best way to plug it off?
Drew
Drew
