Can you cut off the excess length of the stud to clear the oil pump.
Stock main cap bolts do not use washers.
With ARP studs you do use a washer under the nut.
It even possible to notch the casting of the oil pump in a non critical area.
Gene Fiore had to modify the above on his 250 build to get clearance.
