I pulled the LOM dizzy and installed a 68 dizzy to match my Holley 1940.
When I pulled the old dizzy I had the engine at TDC on #1 compression stroke.
With the timing marks lined up on TDC the rotor pointed exactly at the #1 terminal on the cap (3 o'clock), the vacuum advance pointed straight back (12 o'clock).
I installed the new dizzy exactly the same way.
The car cranked but would not start.
I ended up installing the dizzy with the rotor pointing roughly at 5 o'clock and the #1 plug terminal on the cap pointing at 3 o'clock. The engine turns over slow and starts, I moved the dizzy until I got a smooth idle.
Tonight I put a timing light on it and the flywheel mark is so far off counterclockwise I cant see it.
I have always had trouble with this task and this time is no different.
Suggestions?
Suggestions?
