Ford 250 high performance build, and am wondering what's available to boost oil pressure-like a stiffer bypass spring. On the old SB GM we used regular volume pumps with a spring to boost the pressure. with decent clearances the volume was adequate . What do you all do in this regard?
This will be a solid lifter engine if that is a consideration.
My Way
My Way
