Vaughan_D_W
Active member
Ok, so I went to the Pick-a-Part today, and didn't quite get done pulling stuff before they closed, so I'm planning on going back first thing in the morning to continue. This is what I got going on:
Car is an '83 Fairmont. I'm pretty sure it's a 200 with a hexagonal large log head. I'll get a better look at the water pump tomorrow.
1. Dizzy - I pulled what I'm pretty sure is the DSII dizzy. The Falcon Handbook seems to back that up. It's got a big cap on it, a coil, a module mounted on the inside of the fender, and a mess of wires and vacuum lines. The price list indicates a distributor - electronic w/o coil is 40 bucks plus 5 dollar core, a coil is 10, and an ignition module is 16 bucks. It seems to be in a good shape. There's a little wear on the gear, but no play in the shaft at all. It's probably minimal wear on the gear anyway, but I'm not experienced at examining dizzy gears. Doesn't look bad at all. So what do you think? Is this a good buy, or are there things I'm not thinking about that could end up costing a bunch of money, like a fried module or something? What little parts might I be leaving behind? If I just get the dizzy, coil, and module, with attached wires, am I good? I read something about vacuum canisters in the Falcon Handbook, but I don't know . . . Am I better off just getting the kit by the time I spend money fixing all the problems with a junkyard dizzy?
2. Carb - Oh man, if this thing ain't a mess! Wires and sensors and vacuum lines galore! I tore them all off and I'm looking at a rather bulky and ugly mass o' carb. According to the Handbook, it's a Holley 1946, which "became increasingly more encumbered with emission controls and electronic feed back devices and lack some tune-ability" (p. 28). Worth it? Price is 27 dollars plus a 5 dollar core. I might want to use this for a turbo if I also get the next item . . .
3. Head. Like I said, I'm 99.9% sure this a large log, 1.75" carb bore head, which means I couldn't use my Offy tri-carb manifold. Thus the turbo comment above. I'm doing one or the other eventually. It seems to be in fantastic shape. I was talking to another guy next to me who was pulling parts off an El Camino, and when I pulled the valve cover off this head, he said, "Wow, that's a new head!" It's dirty on the outside, but reeeaaaallly pretty on the inside. I want this head. But when I looked at the Handbook, while it says that the '77-up heads are the most desirable (p. 8), the spec charts stop at '80 (p. 7). So what gives? Do the '81-up heads suck because of smog stuff? I can see there's an EGR hole that would need to be plugged on the intake. Actually, that's why I didn't finish pulling it before closing time. I couldn't get the exhaust manifold off because the EGR was blocking my wrench. I'm bringing a hack saw tomorrow. If I go back to get it. Should I, or am I getting an emissions nightmare? Cost is 60 bucks with a 10 dollar core. Hopefully they don't try to charge me extra for the intake manifold.
4. Right next to the Fairlane is a '76 Mustang II with a complete front suspension and steering system. Worth pulling, or would it be the same cost as a kit by the time I freshened up all the worn parts?
I hope there's some night owls out there tonight. I'm going back to the junkyard for the 8:30 opening, in the rain, to get my parts before someone else grabs them.
Thanks for the help, in advance.
