Lokar makes a pedal/throttle cable set up for early Mustangs that looks pretty slick. I had a tri-power on my car (briefly) and use a generic Lokar set-up and it didn't work too well. I even pulled a pedal/cable from a Maverick and that didn't look like I could make it work.
The original Ford linkage hooked up to the Offy linkage with little effort.
I run a short extension (maybe 3"), ends with a threaded pivot bolted to the Offy bellcrank.
Should be able to see it here...
