To do a basic rebuild of a head (at a machine shop), would that be a hot tank, maybe replace guides, install hardened seats if needed, probably mill head to increase CR?
My responsibility would be check valve guide play and CC chambers to determine what/how much is needed.
is there a good way to check the springs to verify they're in spec? all I can think of short of a special tool is to get 2 weights matching their open and closed seat pressure, and measure the spring height under each load. seems hokey to me, but it doesn't seem right to give a mess of springs to someone to test for me. at least, not cost effective. I've just got a mess of springs and I've forgotten where any in particular came from.
I figure if the valves/springs are ok, do a gentle hand lap, disassemble/clean the valve rocker assembly, measure for new pushrods to match the shave, and replace the thermostat.
Am I missing anything? trying to go basic.
