Every 200 weeps there. As we all learned from the guy's post, it has to do with the differential cooling and expansion of the fat and thin areas where they meet. The only way to counter it was provided by that fellow. He ran a fleet of 200s. Essentially, the answer was as Bill said, you mill a trough on both surfaces of the block and the head and seal the joint with an eccentric o-ring in addition to the gasket. Because of the special shape of the trough - square/round - it only makes sense when you have a CAD setup and need to do it to several engines. However, you can get close with a good gasket seal.
Use the 'search' function with key words 'head gasket' and 'leak' or 'sealant'. You may find the name of a good sealant or head gasket.
