SoCar72
Been off-forum for too long. A whole lot of life events : new house (garage!!!, no more parking lot fixes), job promotion, and a newborn. Finally, a new engine for my '63 Falcon is on the to-do list this summer.
I've been wanting for some time to step up to a 7-main 200 (from my 4-main 170). So I've been keeping a look out for low mile used engines and rebuilt ones. I just came across a newly rebuilt (with warrantee) '78 200, D8 casting, high mount starter (I know sometime in the late '70's they went low-mount like the SBF's) and the best I can tell a bolt in for my 170.
Is there any reason I shouldn't go with this engine? Or anything I should transfer from mine to the new one?
Differences I know of :
Rocker arms went from adjustable to non-adjustable
Lifters went from mechanical to hydraulic
Clutch went from 8.5" to 9" - bells changed but the blocks retained dual bolt patterns
Oil shaft and distributor changed from 1/4" to 5/16" (planning on the PD HEI Distributor anyway)
Anything I'm missing? Is there another target casting or year that I perhaps should be looking for instead?
Further down the road, I am planning to swap the head for a CI aluminum, hopefully next summer. So, head issues I'm less concerned with unless there's a real compatibility issue I'm unaware of.
Thanks in advance...
