xpcoupe221":2ibadsfh said:
Thanks for your replys. I am indeed using a C4, so where do I find a flex plate that's correct for a 221? Can I use the 289 157 and remove the weight or is the crank pattern different?
Yes, you can use the 289 157 and remove the weight, but you also have to slot the six indexed bolt holes inwards. Two things are required.
Some important info.
There are small (136), medium (157 or 160), and large C4 (164) flexplates. The Aussie C4 equipped engines had an intermediate 157 teeth size for C4's only. The 160 teeth item is rare as, but every Borg Warner 3 stage auto, Model 35/40/41/51 had the early 160 Small Block Ford Compact Fairlane ring gear.
Any early Aussie or US V8 157 teeth flexplate will work, but the 164 teeth item won't. Cleveland stuff is normally 164 teeth, 28 Oz un balance, but there are 157 teeth 28 Oz flexplates on most C8,C9, C10 equiped 289 and 302's.
An Aussie market 1964 C4 equipped Compact 260 or 289V8 Fairlane 160 teeth flexplate is super rare, and still has to be slotted to fit a small 221 I6.
for the 157 teeth, you'll have to:-
1. "neutral balance" it from the 28 oz 99% of them had [or sometimes 50 ounce unbalance].
That means a professional engine balancer will have to remove the 0.793787 kilo check weight (or on rare occasions, a 1.41748 kilogram weight). Ford did it by cutting out presses steel, or by adding a riveted bias check weight. The guy who does the engine balancing then has to do whatever is easiest to bring it back to perfect balance).
2. Then have a machinist slot the holes inboard to 2-3/4".
NB// All non ohc SBF's have 3" six bolt pitch centers, with one hole out of sync for indexing.
The C4 equipped Falcon or Cortina i6's 1971 to October 1980 have a 157 teeth flexplate you can use, but the same "slot the holes inboard to 2-3/4" requirement" to fit the 1965 to 1970 170188/200/221 engines.
You just have to do the changes. The one size fits all 4.0 DOHC starter motor fits all the wide block 1966 on wards engines, 157 or 160 teeth, as the pitch is the same and 3 teeth don't make a difference.
http://fordsix.com/forum/viewtopic.php? ... 08&start=0
addo":2ibadsfh said:
First picture shows the pre-250/crossflow PCD vs the later PCD.
Second one shows the comparative nature of the two flexplates for BW and case-fill C4. You can see where the balance weights are drilled off.
xctasy":2ibadsfh said:
Addo's shots at top Left. 170/200/221 for 1966-1970. Has 2.75" pitch bolts at crank.
Addo's Right. Case fill 250 C4 flexplate.
My BW 35 auto flexpalte, 1983 item.
BW's have four bolt holes 9.75" appart. If you scale the flexplates via the drawing using the bolt holes, you'll posibly find the C4 one has 10.5" bolt centres. In addition, the C4 flexplate has its ring gear spot welded on, not riveted like mine. There are lots of balance holes that I don't have on mine.
Looks like gassed250 wins...by a nose!
