I have heard that the replacement head gaskets for the 144/170/200 are thicker than the ones Ford used and will drop your compression ratio. Is this correct? I found a Ford gasket on E-bay that is a C9DZ-6051-A. I have a 1965 170. Would this be the correct gasket to maintain the original compression ratio without having to mill the head?
