xrwagon
Hi all, I’ve just done the baby solid cam swap in my 200 with 2V head, mine has the adjustable rocker gear. The head has been considerably shaved and new valve springs. The cam card says 0.014, i cant find what factory setting is for the early solids in 144’s, i thought i read it was 0.018 somewhere. I haven’t set up a solid cam since late 80’s and that wasn’t Ford, I’ve installed the cam, lifters etc, head is back on, valve gear is all on and torqued up, i just need some advice on a couple of things, my motor had a timing set slinger, that fouls the Rollmaster double set i have, so I’m not running it, a performance engine builder local mate set the cam up and installed it, finished that part off, the chain i was supplied was two links to long and its taken a week to get the correct chain, i cant contact him to help me finish it off.
The oil slinger removal shouldn’t be a problem?
And how do i set the solid cam tappets?
Thanks in advance.
Thanks in advance.
