autoX65":20qaz7n2 said:
what setups are good for higher compression like 10.0:1 with stock 250 rods and tempo flat tops? or what is a good option?
None. The rods are crap if they aren't forged, and the pistons are too shallow and not strong enough. Although Does10's did do pretty good before the gudgeon pins froze and took the block out with a turbo engine.
Bascially, the track record on using stock US 250 Ford 6 conrods with 4 cyl parts isn't good. The 103 to even 125 thou piston shortfall still exists, and the compression and ideal dome ins't there. They do allow for over 500 thou lift. They were economy engines after 1969, and thats when Ford started down grading the wall thickness and materials on the economy engines.
There seams to be a prevading need to steal and off the shelf Ford piston while using all the stuff ups that Dearborn put there to make it an economy engine. If they fixed that, it would have been like the Aussie 250, only even better.
All the 250 cranks are underweighed with too few crank counterweights. ( Its an ecomomy engine crank!). It does have a huge crank spigot, good sized main bearings, and can take 302 SBF timing gears, and all that profile cut crank girdle stuff to make it stronger when oil splash is an issue. On a nearly 4" stroke 250 engine, it has 400 Ford style oil splash, and needs some ARP studs, an girdle, and smoothening over. If they made a US 12 counterweight crank, it would be the next option, but they didn't, and the Aussie 1993 to 1997 4 liter 12 counterweight engines were 1.25" crank spigot, not 1.375", so they won't interchange in a US block easily. The thrust bearing is different too. Basically though, the US 250 crank is fine, Ford did a good job on it, just make sure its crack tested, indexed, and prepared right.
The rods, shallow dish 200 piston choices, there all wrong from Ford in 1968, and common almost flat top 255/2.3 HSC piston thinking is wrong today for any 250. A methonal burning 340 HP 250 Aussie engine uses flat tops, and they get torched right through, you can't reduce the compression enough.
None of the info relating to a US 200 engine relates to the 250, as that engine marked the racheting down of the component strength each year, with the 1979 Granada or Monarch being the thirstiest, lamest 250 ever. But it sure makes it a cheap base for an engine that almost has the potential of a 240 or 300. Almost!
The 250s best press was in a February 24, 1979 "Quarantine" episode of ChiPs where Linda Lawrence as Lori says she gets over 27 mile to the gallon out of it. Not that anyone ever did...
