BCOWANWHEELS
well I was going to order a clay smith cam last Monday and I asked them about increasing the size of timming gear dowl pin to sbf size and they instantly to be "no" so off to other cam companys now.
Schneider and Crane come to mind 1st as other folks who have em readily on the shelf at this time…RichCreations":191mbk3p said:On a different note, how many companies make non-stock cams for the small six? I know of clay, comp, and isky...
BCOWANWHEELS":34caseij said:...,isky is don't know about the rest...
chad":bqaktqnv said:BCOWANWHEELS":bqaktqnv said:...,isky is don't know about the rest...
Yes, Mr. Iskedarian's son has started to answer the phone more than he now and is very knowledgable - able to guide you in the design & machining of a new custom cam from their 'shop'.
DOES ANYBODY KNOW IF SCHNEIDER CAMS WILL DO THE SBF TIMMING GEAR MOD ?
Camshaft profiles
To the right is a file system containing various camshaft profiles. We have just launched this information so at the moment there are only a few profiles online. We will constantly be adding more, please check back often!
If you do not see your model in the list please contact us, we have over 2,200 profiles on file. After 26 years in the camshaft grinding business you can imagine how many cams we have worked with!
Most of our cams are regrinds using our customers own cam core, unless otherwise specified. However, we do have a large selection of new semi finished billets. We guarantee all our workmanship. Exchanges available on most models, please inquire.
