After getting the beast back on the road, I now have a weeping head gasket on the driver's side. Here's what I've got:
1. Pulled the radiator cap and have not seen any bubbles while running.
2. Pulled all the spark plugs; I'm running a little rich, but not overly. I'm running 147 mains, but need to drop down between 145's and 140's.
3. Plugs 1 and 2 are a little oil fouled and there was some oil on the end of the threads of plug 1. I'm thinking the valve guides are a little worn.
4. I did reuse the stock head bolts that were on the Aussie 2V when I swapped it in; the PO said the motor only had about 75K miles on it, so I figured they were still good.
5. I'm also chasing the most minute vacuum leak, at the remote air filter (I think), but it hasn't made any significant impact on drivability.
Any thoughts guys? The only thing I haven't done is drained the oil, as the plugs and pistons didn't show any sign of coolant contamination. Should I have just gotten new ARP Head Studs? Should I just do that now? Until I come to that decision, I'm going to drop some leak stop in the coolant; any advice in the meantime would be greatly appreciated.
