Dragonlich1961
I'm having oil pump fitment issues. The pump is interfering with the arp studs. this is a 200ci and a stock replacement pump.
With the main cap torqued to insure main bearing cap alignment and fit, then detorqued and the interfering stud and nut removed, the oil pump is bolted up. With pump bolted there is not enough room to insert the nut and washer. There is not enough room to use just the nut. Is there something i am missing? or am i forced to use a normal main bolt in this location?
A stock Main bolt will clear.
Chris
Chris
