ledslinger29
Anybody got any tips for pulling a harmonic balancer, aside from the Pblaster and an air gun? I've got a three bolt puller on it and it wont budge! Day 2 of the Pblaster soak....
Or the 'heat'n pull' approach ie 'll melt the rubber inside.cr_bobcat":s4iz7zpt said:I used the threaded puller setup Econoline is suggesting. Beware using the hooked gear puller approach. You can pull the balancer apart at the seam.
I had more trouble breaking the bolt loose than pulling the dampner itself. Maybe try a 3 ft section of pipe on the end of your breaker bar. It does take some work. Just make sure you don't bugger the threads of the crank or you're going to be a very sad camper...
ledslinger29":3gyhi89z said:Im using the three bolt puller, with no luck so far. Good tip on not using heat, as I was about to fire it up. I guess I'll just continue the soak.
