ledslinger29
So i'm in the process of putting my 170 back together, and I'm degreeing the cam. I thought i had it all figured out, but putting teading into application almost always leaves me with more questions. I've attached a picture of my cam card below.
My first question is, what exactly does it mean when it says to degree intake lobe to 110? Is that for me or the tech that ground the cam?
Second, i am off about ten degrees on all openings and closings, as an example, my exhaust lobe hits .050 lift at 46 BBDC instead of 36, and closes at -22 ATDC instead of -12. I have the billet adjustable timing chain set set at 0, what is the appropriate correction?
